Graph indices missing
Hi Brian and group,
Build 279 on my iMac running OS 10.12.2 does not show the hourly numbers or the tick marks on the graphs. Anyone else experiencing this?
Aloha,
Mark
there was a change made to the graphing component I use
and this affected the windows version as well
I had to use an older version of that component, as the author of the component said it was as designed now
that fixed it for the windows version
and that should also apply for the mac version…strange
In Build 280, hourly markers and numbers are back, although it takes several minutes after the data appear for them to show. Also correct rain data are back. Thank you, Brian.
I am running build 281 and am seeing this as well.
If you change focus away from weather display then return the indices disappear and take sometimes over 10 mins to return.
it is a change in the graphing component used
the author has fixed it ,they have told me,but only updates it a couple of times a year
