Graph adjustment - how to
After I changed wx-computer my graphs are missing the temp scale in the right side of the graph and the barometer scale miss some numbers too:
How do I correct that?
Henrik
Click “Setup”, then click “Advanced/Misc Settings”. Then check the box that says “Enable Move/resize of objects”.
Then go back to your window, put the cursor over the graph section, hold down the < ctrl > key and move your mouse to the left. The graph box should get bigger. Once you’ve made the box bigger, then you’ll need to move everything over a bit to get the left hand scale moved over.
Hi smasraum
Thanks for your reply.
I think you are meaning the graphs in the main screen ?
I should have mentioned that the problem occurs in the 6-12-24-48 and daystamped graphs (ie. www.silkeborg-vejret.dk/vejrdata/20091220.gif)
Henrik
oops, sorry, yes, wrong graphs.
Hi again
Problem solved - I opened the graph history in WD and resized the windows and now its working.
Henrik
