Hi, Does anyone have a working installation of the GFS maps creation with OpenGrads running? I used to have it running with the nordic.gs file + bat file original created from Henkka (weatherc) … I havent used it for some years because of a computer change - but wants it up an run again.
But now I cant get it to work. I have installed the newest version of OpenGrads and a version of the Nordic.gs + bat file that I have been able to find her. But I get this error from OpenGrads
Config: v2.2.1.oga.1 little-endian readline grib2 netcdf hdf4-sds hdf5 opendap-grids,stn athena geotiff shapefile Issue 'q config' and 'q gxconfig' commands for more detailed configuration information Loading User Defined Extensions table ... ok. GX Package Initialization: Size = 11 8.5 Running in Batch mode Command line history in \Users\soren/.grads.log All files closed; all defined objects released; All GrADS attributes have been reinitialized OC xxdr depends on the assumption that sizeof(off_t) == sizeof(void*) syntax error, unexpected WORD_STRING, expecting WORD_WORD context: Error { code = 0; message = "/gfs_0p25/gfs20200418/gfs_0p25_00z.das is not an available dataset"^;}; Error: nc_open failed to open file https://nomads.ncep.noaa.gov:9090/dods/gfs_0p25/gfs20200418/gfs_0p25_00z.das NetCDF: Malformed or inaccessible DAP DDS gadsdf: Couldn't ingest SDF metadata. No Files Open
My question is: Does the nordic.gs script work anymore? does the bat file work ? (both attached in .txt version)
Does this work at all? All help and input appreciated.
Thanks, Soren
gfs_bat.txt (431 Bytes)
nordic_gs.txt (37.5 KB)
