GFS data for forecasting
Hi Ton.
It would be worth reporting that in the WxSim board and hopefully Tom will see it. If WxSimate is creating the file it seems odd that WxSim can’t find it! Have you looked in the file after WxSimate has finished to see if it has anything in it?
Chris
Hi Ton
Have you tried turning off autoforcast and manually import the data in WXSIM - at that point you should choose your datafile from WXSIMATE. When you have done that you can turn on your autoforcast again.
Hope that helps
Henrik
Henrik,
Thanks for this tip, It got my WXSIM going again! What a program…
Hi again Ton
Im glad you got it working.
Henrik
Chris, Stuart and everybody else involved!
Thank you for your hard work, GFS works and everything with all that strange errors are gone.
Bengt
I’m sad to tell you that the WXSIM forecasts I am getting are fairly wrong at the moment.
It’s snowing right now and next night it will be freezing -4 to -6 celsius locally.
WXSIM does not show any of this and says someting like Foggy and +3 degrees C.
Ton do a manual import and make sure that on that screen you have the RAOB and GFS/READY option radio buttons checked. I found that mine were missing after I lost the import file name as well.
