The ‘fullscreen’ button no longer seems to work on WDL (try it here: http://weather.otronics.co.uk
Clicking the button doesn’t seem to do anything.
I’ve turned off the pop-up blocker and tried various browsers.
Any ideas?
Any ideas?
What happens when you view it directly and not controlled by your page code http://217.199.187.197/otronics.co.uk/Weather/wdl.html ?
I can view the page direct via http://217.199.187.197/otronics.co.uk/Weather/wdlv6_09.swf?http://217.199.187.197/otronics.co.uk/Weather/wdlconfig.xml and it opens fullscreen as soon as the page is loaded.
The button still doesn’t do anything.
I cannot see the full screen button on your site.
Have you got it enabled in the config file:-
1
1
I couldn’t get it working so have removed the button.
As far as I know you only need to put the right code in the config file, there is no other mod needed.
If you reinstall the button then I will see if it works for me.
What browser are you using?
It worked for me before the direct url to wdl was changed, it didn’t work in the template page.
