I have noticed some times WD stops ftping the clientraw.txt file to the web page every few seconds. Running more than a few programs on the WD machine may cause this slowdown. A WD restart will result WD ftping the clientraw.txt file to the web page every few seconds again.
I have the clientraw.txt file (in the
try ticking reset the ftp error count
and set the log out/ re login frequency to a smaller number
Thanks for the suggestion.
I have always had reset the ftp error count ticked.
I have always had the Log out/re-login frequency to Every 5 minutes ticked.
In order to have the clientraw.txt file ftp to the web page every few seconds I had to set the above options (some time ago).
humm
it should recover
you can check under view, ftp log, view real time ftp, to see what its up to, when it stops
