Ftp upload not working (2)
This may be my stupidity rather than a bug but…
My auto ftp upload stopped working after I upgraded to 10.14. I made no other changes. I was running 10.13w prior to upgrading. It was uploading to weatherunderground on 15 minute schedule and uploading to my web site on 30 minute schedule.
I found version 10.13r. It is running right now and it works fine.
Also, the watch does not start in 10.14 as it did in earlier versions.
any errors under view, program error log when wd starts up?
also, check any firewall is letting the ftp access…as i there has been a change to the ftpupd.exe program
not sure about wdwatch…it works here when i have tested with the latest version…might be related to any program error log event
I found the problem. On my end of course. In the past I’ve always downloaded the whole program and did an install. Well on the last one I noticed I could just download the zip file, which I did. When it was unzipped I noticed I had a new directory, WeatherD. I reset my shortcut to that directory and that’s when the problems began. I copied the .exe and other files to the original directory and everthing now works. :oops:
Since I am using WD as both a server and client, could I completely remove WD on the client machine, reinstall and have all of the data still available. I do all of the work on the client and have the data logger running on the server. Hope this makes sense.
yes
with the client version, set the location of the data files and logfiles to the server …and tick to share the datafiles and logifles…see in the extra/misc settings
