Whenever I try and upload from WD to my homepage, which I am having ONE HECK OF A TIME, my ftpupd icon shows up then seems to stop. If I hit Ctrl-Alt-Delete, it says that ftpupd is not responding. Any ideas anyone?
David
David
What does your FTP log say?
C:\WDISPLAY\webfiles\David’s Weather Station.html
FTPUPD.EXE finished at 5:39:27 AM 2/15/05
Time taken = 1.48 minutes
Total bytes uploaded = 1001 K
Total bytes uploaded for the month = 10161 K
Error Failed to connect: [10060] Connection timed out with FTP transfer
Error occured at:4:07:44 PM 2/15/05
Error occured at:4:13:00 PM 2/15/05
Error occured at:4:14:28 PM 2/15/05
Error occured at:4:23:24 PM 2/15/05
Error occured at:4:29:06 PM 2/15/05
Error occured at:4:46:44 PM 2/15/05
Error occured at:5:04:26 PM 2/15/05
Maybe combine this with…
http://discourse.weather-watch.com/p/43815
in WD click on view, ftp log, then click on view, full log
and post what appeas there here
its either you do not have the ftp details set correctly in the connections setup, or a firewall is blocking ftpupd.exe
C:\wdisplay\webfiles\David’s Weather Station.html
Start Time/date:5:42:14 PM 2/15/05
Finshed email agenda
Finshed email agenda, and more Internet agenda items to do…
Time/date:5:42:16 PM 2/15/05
Logging onto FTP server…ftp.geocities.com
Connecting to FTP server.
FTP error occured
FTP error, looking for next agenda item
10060: [10060] Connection timed out
Checking for next FTP agenda…
there are 1 more things to do
Checking there are files to upload
There are more files to upload
FTP error occured
10060:
No more files to upload
All Agenda complete, doing FTP log off…
FTP logoff
Will stay connected…
Logging onto FTP server....ftp.geocities.com Connecting to FTP server. Failed to connect: [10060] Connection timed out
ftp.geocities.com I can establish a connection to here with WS_FTP, so it looks like you have a firewall running that is blocking the access of WD’s ftupd.exe program
you will need to check and configure your firwall to let the program ftpupd.exe through
it might even be XP’s firewall you have in use that you will need to configure (see in windows control panel)
once you get the firewall to let it through (which is not a fault of problem of weather display), then post here the results from that same ftp log full data
Tell me more, you have my attention. Now, I am running an oler Windows, 98 in fact, also, I have Norton Antivirus 2005 running, but, auto-enabled, is turned off. How do I get around the firewall so that this will upload?
David
norton antivirus is your problem
it takes over your PC and its very hard to get it to change its mind,and even harder to turn it off
alot of people use Zone alarm (there is even a free version)
that is half your problems, using that program
just ask Joseph Toubes, a member of this forum about all the problems he has /had with norton
THANK YOU so much windy, after supper i plan on shutting that down, i would like to keep it, but at my time. I had thought that might have been a problem this morning, but wasn’t sure
David
good luck with your restle with norton firewall…and let us know how you get on
(and try the free download of zonealarm.com
