FTP problems
I’m having a problem with ftp. My uploads work fine for a variable time period (1-approx 10 hours) then they stop. When I look at the ftp log I can see that things are uploading fine, then it seems to stall and the ftp program times out. Once that happens no more uploads occur (although the client raw files sometimes keeps updating but eventually stops).
I’ve tried changing all sorts of settings, stopping uploading webcam images, disabling and changing firewalls etc. but nothing seems to help. The stalling occurs on all sorts of files. E.g. .gif, .jpg and .htm files.
I’m using the latest version of WD and this problem also occurred with previous versions.
Any suggestions on a fix would be great.
What station do you have?
will not be related to the weather station type
but more related to some problem with your FTP/ISP provider
what is the errors showing in the Ftplogfull.txt file?
thanks for the replies.
the station type is oregon wmr200.
See the error log below. I’m getting a connection reset by peer error if that helps.
thanks
Time/date:4:30:26 PM 9/05/2015
Logging onto FTP server…####
Connecting to FTP server.
OK ->####.####.####.##
Connected.
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 7 of 50 allowed.
220-Local time is now 16:30. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
USER=****
331 User #correct user name##### OK. Password required
PASSWORD=****
230 OK. Current restricted directory is /
TYPE I
200 TYPE is now 8-bit binary
Changing Directory to #correct directory#####
CWD #correct directory#####
250 OK. Current directory is #correct directory#####
Checking for next FTP agenda…
there are 1 more things to do
Doing ftp upload
Checking there are files to upload
There are more files to upload
PASV
227 Entering Passive Mode (103,18,110,205,184,158)
150 Accepted data connection
10054: [10054] Connection reset by peer
that sort of error is on your FTP/ISP host end
maybe try contacting them about the issue?
remote chance, try unticking to use passive mode in the connections setup
Thanks for the help, I went through heaps more options and asked my FTP/ISP host all was OK from there end.
Finally after I reinstalled the ftpupd.exe everything is now working fine. :slight_smile:
