FTP failing to upload .txt files
I have a VP2 station and the latest WD running on Windows 10 which has worked seamlessly for years. Since the 15th September the FTP upload has failed with the following error codes:
FTP Uploading C:\wdisplay\webfiles\clientrawextra.txttemp - >clientrawextra.txt
PASV
227 Entering Passive Mode (46,30,211,122,209,206).
STOR clientrawextra.txt
uploaded ok 11:53:45
550 Requested action not taken. File unavailable (e.g., file not found, no access).
141: FTP protocol error: 550 Requested action not taken. File unavailable (e.g., file not found, no access).
FTP Uploading C:\wdisplay\webfiles\clientrawhour.txttemp - >clientrawhour.txt
PASV
227 Entering Passive Mode (46,30,211,122,209,217).
STOR clientrawhour.txt
FTP Uploading C:\wdisplay\webfiles\clientrawdaily.txttemp - >clientrawdaily.txt
PASV
227 Entering Passive Mode (46,30,211,122,209,182).
STOR clientrawdaily.txt
Any thoughts on what is happening?
Check to make sure that you’re able to manually upload a file to your server. I think it’s uploading a file and then trying to rename it on the server. It looks like the upload is reported as successful but the rename fails. Maybe the upload is failing somehow, e.g. out of disk space, a permissions problem, or some other reason, so the rename operation then fails.
Just transferred the clientraw files manually using Filezilla and that worked.
Somehow the directory structure on the server had changed without any intervention from me. The WD files had gone from the root to a folder called httpd.www Weird!
Added the new directory and everything is working OK. Thanks for the support suggestions.
I’m having exact the same problems since 22/09. This is what my ftp log looks like:
Please notice that I omitted the ftp server address below
Weather Display FTP/Internet vers 9.29
Time/date:9:36:09 28/09/2022
Logging onto FTP server…**************
Connecting to FTP server at *************
OK
Connected.
220 ProFTPD Server (FTP Server) [::ffff:83.217.74.233]
USER=****
331 Password required for acdeinzebe@acdeinzebe
PASSWORD=****
230 User acdeinzebe@acdeinzebe logged in
TYPE I
200 Type set to I
Change to remote Dir /weer
CWD /weer
550 /weer: No such file or directory
141: FTP protocol error: 550 /weer: No such file or directory
Checking for next FTP agenda…
there are 2 more things to do
Doing ftp upload
there are 1 more things to do
QUIT
221 Goodbye.
OK
Disconnected.
Try logging into your server manually and check whether the folder structure had been changed. Sometimes hosting companies might do that when changing their systems not realising the effect it could have in automated uploads.
