FreshWDL Rainfall Last 31 Days not picking up corrected rainfall data from WD?
Earlier this month we had a cyclone pass through and the winds were so strong it was freaking out my Tempest station reported 46mm of rain when we only had 7mm of rain. I’ve fixed it all just fine in WD using View → Averages/Extremes → Correct/Check The Data function and Weather Display shows my corrected amount everywhere I look (Averages/Extremes, Detailed Rain Chart, etc…).
However, FreshWDL is not picking up the corrected data and still shows 46mm on that date when it should say 7mm. I read on another post that WDL’s data / graphs only update once a day, but I made this change/correction over a week ago. So there must be something else I need to do?
I had this problem recently, see here.
It would appear that you can’t correct clientrawdaily.txt unless you can make the rain corrections in the log, convert to data and then recreate the last 31 days. For me, that was impossible.
