I have had Consolewd uploading to Freshwdl for a week until yesterday when it started to display the image below.
Is there an issue with the Freshwdl server?
Consolewd from my Pi is uploading all the files correctly.
url?
I guess you meant my weather station upload url,
https://www.qsl.net/g/g4bgq-drm//index/weather/FreshWDLmaster.html
I suspect there is something about the clientraw files from consolewd it does not like
I do see a % sign that should not be there:
https://www.qsl.net/g/g4bgq-drm//index/weather/clientrawextra.txt
try editing that out as a test?
also clientraw.txt is missing the 10 min average windspeed at the end
which I can add
and its missing data from the end of clientrawextra and some things for clientrawhour at the end as well
which I can add
Thank you, I’ll look into it. I have restarted consolewd so data uploads are now current.
Freshwdl is working again this morning, so It seems it was not a problem with my system.
It really needs Freshwdl to be a complete application without relying on an outside server.
it still might have been something it did not like at the time with the consolewd clientraw files?
