I have FreshWDL working at www.deepskyridge.com on Firefox browser.
It does not work on Chrome.
Any ideas.
Gary
Any ideas.
Gary
Working fine here on Edge and Chrome. . . try Ctrl-F5 in Chrome to refresh?
Worked fine to bring up your site on Chrome for me.
I downloaded Edge and it says Data Currently Unavailable … just like the others.
It only work on one browser one one machine.
I am going to try moving the clientraw.txt files to the same directory as FreshWDL.
Just guessing.
Gary
Working fine here under Chrome on OSX and Win10, and also under Edge on Win10.
Your profile says you are running “Win NT 6.3”. Is that Windows 8.1?
I think that is usual. . . otherwise you have to edit config.js to set the path.
Yes, I am running win 8.1
Gary
I honestly don’t know if that is a problem or not, I can only say that your FreshWDL is still working fine in Edge and Chrome here. Sorry.
i would suggest that using an old version of windows will be an issue
(as its not up to date with https and similar newer protocols)
if you have a pc with windows 10, try that
I have 3 p.c.s with win10 and they all do the same thing.
Gary
I use chrome on W10
and your site is working OK
http://www.deepskyridge.com/
do try though a ctrl F5 web page forced refresh
Your site is working without problems using Edge, Chrome and Firefox in the UK so it does see to be something on your local network that’s causing the problem.
Are there any obvious differences between the one PC that works and the others that don’t, e.g. how they connect (wired/wifi), are they all using the same router, same/different anti-virus/firewall products, etc?
I feel kind of like a dog chasing it’s tail.
This morning all 3 browsers (Edge, Chrome, Firefox) all work fine with FreshWDL.
Gary
Using Safari on ipad and fresh wdl showing as…
FreshWDL
Collecting Data.
Any ideas?
Ps also the same on my android note 10 plus using chrome
Oops. Just saw the change of address for one of the files and will try that.
Steve
Same here. If anyone wants to take a look at it, Tempest
It did the same thing about 10 days ago(?) and then suddenly went back to running normally. Firefox, Edge, Chrome, Android.
https://weather.scottsworld.info/wdlive.html I haven’t touched this page in months and noticed this morning its not working
I am having similar issues.
https://www.ndtech.org/weather/
Works fine as usual on Win 10 PC running Edge.
NOT working on Android phone running Edge. It used to work fine here too.
Ian
You don’t seem to have made the changes in IMPORTANT - FreshWDL server upgrade yet. The old CDN is broken so your site won’t work reliably (or probably at all) until you do.
