Hi, I must have been asleep when this came out, I only knew about it the other day when I posted about WDL using flash. My question is how hard is it to install, I cannot seem to find anything about it, or am I missing something somewhere.
teal.
teal.
its very easy to install
set a couple of settings in the config file (e.g the url to your clientraw file)
upload the files to a directory on your web site
then view the web page (freshwdlmaster.html) in that remote directory in your browser
Home page GitHub - Yerren/FreshWDL: FreshWDL is a pure JavaScript alternative to WDL.
Forum thread JavaScript WDL version 1.0.0 alpha.
I just uploaded the files to the same place as WDL, there’s no confusion. And it works well!
Thanks guys for the help, I take it that it does not use flash then, it’s a replacement for the flash version, I will have a go at it latter.
teal.
Great to see FWDL and mine is here Weather Display Live.
Only it isn’t updating every few seconds like WDL does - the clientraw.txt files are definitely being updated tho’.
Have I missed something?
John D.
PS, Hhere’s my html file:
FreshWDL<!-- Loading Screen Setup -->
<div id="loadingScreen">
<div id="loadingText">
<p id="titleText">FreshWDL</p>
<p id="loadingMessage">Collecting Data.</p>
</div>
</div>
<!-- First script that must be loaded -->
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/js_bundles/Loading.js"></script>
<!-- Include remiaing Scripts -->
<script type="text/javascript" src="config.js"></script> <!--Includes the local script that sets customisable variables-->
<script type="text/javascript" src="https://code.createjs.com/easeljs-0.8.2.min.js"></script> <!--Includes the drawing part of CreateJS: EaselJS-->
<script type="text/javascript" src="https://code.createjs.com/tweenjs-0.6.2.min.js"></script> <!--Includes the animation part of CreateJS: TweenJS-->
<script type="text/javascript" src="https://cdnjs.cloudflare.com/ajax/libs/opentip/2.4.6/downloads/opentip-native.js"></script> <!--Includes the tooltip library: OpenTip-->
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/js_bundles/moment-with-locales.min.js"></script>
<script type="text/javascript" src="https://cdnjs.cloudflare.com/ajax/libs/Chart.js/2.7.1/Chart.min.js"></script>
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/js_bundles/Globals.js"></script> <!--Includes the script that sets global variables-->
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/js_bundles/WidgetsHandlers.min.js"></script> <!--Includes most of the Scripting-->
</body>
its updating every few seconds for me when I view your site
maybe try a different browser or use ctrl F5 to refresh the page
I see the windspeed updating every few seconds.
Is there a limit setting for how long it will continue to live update (anti camping) ?
Thanks Brian, that’s interesting. Apple/ Safari seem to be at the root of the problem - I also have to force WD to refresh otherwise past data (the main display *.gif file doesn’t refresh - a problem that started recently.
how do you mean by force WD to refresh exactly?
