Forecast Icon & %weathercond%
Been dealing with this issue for some time.
Started around the switch to the new compiler I think.
Using the metar to update the forecast icon, with the box check so my stations fog,rain,wind will over ride this.
Running the custom update on many items at every minute.
All the time I just get the partly cloudy no matter what conditions I get from the metar. Once the station has rain wind ect it will show that. Any other time it will not show the metar conditions like it has in the pasted, Overcast, clear ect…
I have found if I set item #21 Metar.gif in the advance internet settings to create I can get the downloaded metar conditions to properly be reflected in the Forecast icon & %weathercond%. The problem with that is the stations own weather conditions will not over ride the forcasticon. I will show the proper information in the %weathercond%
I have looked all over and tried many settings throughout WD but I may be missing something new as I have been running WD for a very long time.
Running WD 10.37Q Build 34
Windows XP Pro
Davis Weather Monitor II
No solar sensor gear.
After watching this problem longer.
It looks like the only thing that is not working correct is when the Metar I down load says Overcast WD will not reflect that. It will just show the Partly cloudy icon.
I know its a minor issue just wanted to see if anyone had an idea.
Is your website updating correctly?
I’ve been having metar update problems at night. WD icon shows correct, but doesn’t pass correctly through clientraw.
http://discourse.weather-watch.com/p/390157
The web site is updating. Just will not show the correct icon for overcast. When the Metar says over cast I get the Cloudy Icon both day and night.
Scott
