Fog Icon but I don't have any.....?
I’ve seen posts about users having fog but no fog icon showing up.
I’ve got the fog icon but no fog. Even when I set the fog icon temp to it’s lowest setting (-10C) and my humidity is at 90%, I still get the fog icon and the “current weather” reads fog. It’s CAVU…
any ideas, weathermen/women?
humm…
are you using a metar to update it maybe?
but if the current condition says fog:
try setting the fog icon threshold to 100%
No metar, the fog icon temp threshold set to -10C, the fog icon humidity threshold set to 100%.
In general, how is humidity measured when the temperature is below freezing? I think my humidity sensor must be frozen…
humm, it still should not get shown…check also though under input daily weather you do not have it set there
humidity sensor:
its a capapacitor type sensor usualy…as long as no moisture on it to freeze it still shoule keep working
its great to think i have a wd users in alaska and near the south pole
No, it’s not set under “input daily weather” What I did to stop it is offset the humidity by -1% as a test.
I’m honored to be the furthest north user of WD! I will endeavor to bring you the latest in cold weather issues.
