While using Build143 and 101 my main screen solar display got messed up (it’s NOT A SOFTWARE PROGRAM PROBLEM) it’s an io (idiot error) on my part
Can someone give me the steps to fix this?
I don’t use the Windows version so I’m afraid I can’t answer your question.
I thought you might like to know that your issue is usually referred to as PEBKAC - Problem exists between keyboard and chair :lol:
now :lol: that’s funny right there
that looks like the solar graph needs regenerating use log to graph and look for the 82022vantagelog.txt then do the 82022lg then the 31 day
Don’t know if this is still valid but came up in a search of the forum:
Quote from: docmarv on August 01, 2022, 09:24:13
Quote from: hcorrin on August 01, 2022, 12:54:47
So Hey hcorrin
i needed to go to “Action”
“convert log file to data file”
find 082022vantagelog.txt
A) convert solar log to solar graph
B) select 82022lg convert?
C) Re create the last 31 days graph data?
yes that it but your image is showing A against indoor not solar
yes that’s what I meant
thanks, hcorrin
Hello Harold,
When I regenerate the ave/ext data, the program doesn’t create the wind data as on your page https://www.hc-iom.co.uk/WD-AJAX/wxgraphs.php
Do you know what I am doing wrong? http://www.docmarvweather.com/20190304.gif
Try restarting WD. I get a blank chart sometimes after making changes in WD and then a restart usually fixes it.
Hey Thanks, nice web-site btw
Thanks for the comment about my website, which I’ve been tinkering with and tweaking for years but the real credit goes to those who designed the templates and code, otherwise I wouldn’t have anything to build upon.
Template design by CarterLake.org (http://www.carterlake.org/) with PHP conversion by Saratoga-Weather.org (Saratoga-Weather.org - Home / Forecast).
Special thanks go to Kevin Reed at TNET Weather (https://tnetweather.com/) for his work on the original Carterlake templates, and his design for the common website PHP management.
Special thanks to Mike Challis of Long Beach WA (Long Beach Weather - Long Beach, Washington 98631 USA) for his wind-rose generator, Theme Switcher and CSS styling help with these templates.
Special thanks go to Ken True of Saratoga-Weather.org (Saratoga-Weather.org - Home / Forecast) for the AJAX conditions display, dashboard and integration of the TNET Weather common PHP site design for this site.
Thanks to Yerren van Sint Annaland. More information is available at: FreshWDL on github (GitHub - Yerren/FreshWDL: FreshWDL is a pure JavaScript alternative to WDL.).
Scripts by Jerry Wilkins at SELincoln Weather (https://gwwilkins.org/).
And others…
