How do I fix that Windy? I believe I have all my things setup correctly, unless I am missing something. Almost got it.
Chuck
Chuck
Bob,
Here is pic of my realtime settings. Tell me if they are correct.
Realtime settings.doc (118 KB)
note that the ftp settings you have set there, and you have ticked, use these ftp settings, is really only intended if you wanted to use different ftp settings than what is set in the main ftp settings in the connections setup in the ftp/internet setup
alot of people do that, never mind
do you have the clientrawrealtimeftp.exe program running, and WD running?
You also need to make sure you have “Control Panel - FTP - Connections - Main Internet Switch” Turned on…
I have the main switch on. It is still not updating. Windy both of the programs are running.
Chuck
you should have a yellow flash icon down by the clock
double click on that, to make the real time ftp program come up visible
then check whats happening and if you can post the detaiols here
i suspect the problem is you have the remote directory set wrong
you have www/chucksndweather.info
in the real time ftp setup
that does not look right, the .info on the end
i.e a remote directory is not a URL, thats a commen mistake
Windy,
I do not have a flashing yellow icon in my system tray. I must be missing something.
Chuck
its not so much as flashing, its looks like a yellow flash
you might have closed it down then
restart manualy the clientrawrealtimeftp.exe program bu double clicking that program where you have WD installed to get it running again
Ok…
In your settings you have…
“Do not show an icon in the system tray” ticked so untick that so you at least can see that it is running…
And as Brian pointed out /www/chucksndweather.info will not be correct…
Maybe just /www not sure depends on your host set up.
I am having all kinds of problems. When I restarted my computer and brought up WD my VP2 console froze and no it will not do transmit to get data. This crap is driving me nuts and of course my site not updating properly is not helping at all. Very frustrating.
Chuck
I finally got it to work. Just kept on playing with it and it finally updates properly. I would like to thank all how helped me out. I have learned a lot in just the past couple of days. Please check it out to see if it works. Thanks again to all.
Chuck
Chuck looking good to me
Now you need to sign up as a clientraw provider… FREE
Here:
http://wxd.weather-watch.com/amember/signup.php
Then your station will be available for those running MML to have displayed on their maps…
Nice job Chuck. Now I’ll be able to track those Alberta Clippers!
Have changed it now… but still no luck in firefox?
Just have another question. The realtime ftp works for about 5 minutes or so and stops working or a second icon appears in the system tray. I don’t know what is going on but still working with it.
Chuck
Hey Unripegreenbanana.
Your config file is mucked…
XML Parsing Error: undefined entity
Location: http://homepages.xnet.co.nz/~foggy/wdlconfig.xml
Line Number 146, Column 12: <caption> </caption>
You may want to reupload it or check and make sure you haven’t lost a required element…
Changed it now, still wont work in firefox for somereason
I think you are missing something in your html file…
This is yours:
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,0,0" width="550" height="400">
<param name="movie" value="wdlv4_10.swf?http://homepages.xnet.co.nz/~foggy/wdlconfig.xml">
<param name=quality value=high>
<embed src="wdlv4_10.swf" quality=high pluginspage="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="550" height="400"></embed>
</object>
This is mine:
<OBJECT classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=7,0,0,0"
WIDTH="100%" HEIGHT="100%" id="wdlv4_10.swf" ALIGN="">
<PARAM NAME=movie VALUE="wdlv4_10.swf?http://JaxWeather.net/flash/wdlconfigmml1.xml">
<PARAM NAME=quality VALUE=high>
<PARAM NAME=wmode VALUE=transparent>
<PARAM NAME=bgcolor VALUE=#FFFFFF>
<EMBED src="wdlv4_10.swf?http://JaxWeather.net/flash/wdlconfigmml1.xml" quality=high bgcolor=#FFFFFF WIDTH="100%" HEIGHT="100%" NAME="wdlv4_10.swf" ALIGN=""
TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer">
</EMBED>
</OBJECT>
Thanks very much. I’ll copy that code (apart from urls!)
Cheers
