I went to use this file on my website but the image has about 20% missing from the bottom.
Is there anyway for me to fix this or is the problem within the program code?
what is the URL to the image on your web site?
does the image file look OK in the WD web files folder?
The file is locatedin WD “web files” folder and is faulty there. because of this I have not loaded it up to the Website as yet.
what does it look like under view, weather dials in WD itself?
if its large there
then try
setup, advanced/misc, main program
and click on reset weather dials
Thanks Brian, I tried all suggestions but no change, unfortunatly there is no provision to resize the image.
.zip and email me your settings files and I will fix the problem for you
Thanks Brian, before I waste a lot of your time could you narrow down just which “settings” files you want, e.g. every settings file on the computer, all settings files in WD ???
There is a FAQ for which files he needs and how to zip them up and send them.
- Jim
Thanks Jim,
Your intensions were intended to be helpful, but the FAQ files are extensive and difficult to navigate with no index or subject grouping, I have just spent a half hour trying to locate the entry to which you refer, without success, I now fear that Brian will have seen your post and will not bother to answer my questions.
Rob,
Sorry about that, but here is the FAQ http://discourse.weather-watch.com/t/12684 for how to do it. If you’ll include a link back to this thread in your EMail to him, he’ll know exactly where to reply and you won’t get “lost in the shuffle”.
- Jim
I replied to the email yesterday about how to fix the problem
The problem is now resolved, thanks to Brian and Jim, et al.
Rob.
