Fct_yrno_popup2
sometimes the page fct_yrno_popup2 shows very large icons when it opens
anyone have an explanation
Hi Tore Bjaland,
Welcome to the forum.
Attached screenshot shows on the left your graphs and the detailed data.
On the right the current version of the scripts as from
PWS_Dashboard 2012_lts updates
2024-01-27 Free download: graph_forecasts.zip
The first minor problem is is missing bottom part of the graph. That is solved in the 2024-01-27 update.
The major problem is an incomplete last day-part data which causes a partly filled column on the right.
This is the first time I see this, will try to find a solution for that.
Confirmed your problem on my test website.
It is caused by incomplete data for one day in the middle.
The first 3 days have complete data.
The yrno data switches from 1 hour data to 6 hour data and this causes incomplete data with your timezone location of UTC+8.
The scripts should not fail, but sadly they do.
I tried a few work-arounds but the problem seems to complex to solve shortly.
Best way to go is to only use WU data as that works already OK on your site.
WeatherUnderground Forecast
I will test further to find a solution for YrNo.
Thanks for the reply and thank you for doing a good job
