False Reading - Soil Moisture: 255.0 on Wunderground
I keep reporting a Soil Moisture: 255.0 on wunderground. I do not have a Soil Moisture for my Davis VP2 and I am unable to locate where that reading is coming from within Weather-Display. I am running WD10.37 Mac296. Wunderground station ID-KWAPOULS28
Thanks in advance for the help,
Sean
WD should be sending a blank (null) value if the data is our of range
check what is actually being sent
see in the sentwudata.txt file
It is sending the value of 255.0 for the soil moisture.
2018-01-11+16%3A37%3A00&winddir=129&windspeedmph=2.8&windgustmph=5.0&humidity=97&tempf=45.5&rainin=0.12&baromin=29.711&dewptf=44.7&weather=RA&clouds=&dailyrainin=0.31&solarradiation=0.0&soiltempf=&soilmoisture=255.0&leafwetness=&UV=0.0&softwaretype=WeatherDisplay%3A10.37Mac
Sean
OK, I see the problem, it is the rapid fire data that is sending that
I will get an update out in the next hour to fix this
Thanks for the rapid fix ;-).
Sean
ready to download
