I’m running Weather Display version 10.12m and I have a question about the Extreme Conditions section on the main screen. For some reason where is shows Minimum Temperature the time says 00:01 a.m. I also get this reading a lot for a few of the Extra Daily High/Low Weather parameters page readings as well. Any help would be appreciated, great product!
humm…it does seem a bit suspect to be at that time…
the temperature hour of reset you can change…
the default is midnight…
so it might be that the coldest part of your night is prior to midnight…
and so it resets at midnight, and so the time is then…
but that temperature minimum is then never reached again…
you can move the mouse over the main screen graph, and the time is then displayed and the temperature displayed, and that way you can see the actualy temperature readings during the night
also see under view, real time graph, or double click on the windspeed scale to get to that graph…
