Extra_temp_block.php
Hello,
Can someone tell me where I can copy the extra_temp_block.php script
I have an extra sensor Ecowitt Model WN31B
thank you
Marian
Hi Marian,
Can you post the URL to the site?
If it is an ecowitsite, the block can be selected in easyweather and it will work.
Make sure the sensor is visible on the console and or in the app.
If it uses another weatherstation-upload (f.i. Davis) you have to use easyweather to tell which upload you will be using. there is a selection to use ecowitt custom upload for some extra sensors.
The current pwsWD 2012_lts release does not support extra TH sensors this way.
As you are using the beta version, the easyweathersetup also can use ecowitt custom upload for add-on TH sensors.
Thanks for the prompt response.
Extra sensor Ecowitt Model WN31B I use it together with other extra sensors, lighting, AQ, extrasoil, leaf, with the Ecowitt GW1100 station, and Ecowitt HP2560_C.
display in Toronto Personal Weather Station (ecoAPI version). Here I only displayed a small module in the first place.
I want a big block, extra_temp_block.php.
I don’t have the ecco_lcl_arr file in the ecovitt directory.
Marian
All the Ecowitt sensors I have can be seen here
https://www.ecowitt.net/home/share?authorize=6WJR02&device_id=NXEvWTg1NW5zTFcxaXpVV1B1QlZvQT09
Just select the block in easyweather setup.
The block is operarional.
It shows the same values as the small block for one extra sensor.
I can not read the images from your settings.
But these are station-sensors, they are standard included in your ecowitt-aspi.
You do not have to set anything else.
Debug console:
All received data is in the debug-console also (bottom row left button) or use this link
https://www.celinmeteo.com/wdisplay/pws2024-12-01-Ecowitt/PWS_listfile.php?file=jsondata/ecowitt_api_08F9E0780D03.json&type=json
All processed data debug-console → bottom row right button or use this link
https://www.celinmeteo.com/wdisplay/pws2024-12-01-Ecowitt/PWS_listdata.php
Thank you!
:smile:
Marian
Two questions:
1.
lightning_wf_small.php has little information it is possible
make a module something like lightning_wf_c_block.php to include more data
distance today, Daily count, 1 hr min /km, Daily min /km
https://www.celinmeteo.com/wdisplay/pws2024-12-01-Ecowitt/index.php
The fact that I don’t have the ecco_lcl.arr file in the ecowitt subdirectory from pws2024-12-01Ecowitt no does it negatively affect the page?
Hi Marian,
You are using an unsupported version of PWS_Dashboard and you are also the first user of the Ecowitt-api
So not all functions will work as smooth as with other more often used weather programs.
Currently 2025-01-06 08:00 UTC you are using the lightning block for ecowitt-api data.
As told before, the ecowitt-API delivers not enough information for the lightning sensor. F.i. Not the date/time of the the last lightning
it is shown on the ecowitt website, but not in the data downloaded from ecowitt.
If you stop using the ecowitt-API and switch to the ecowitt Custom upload, the lightning block will look better.
If you own a weatherflow device you can use the data from that devices for lightning.
