How do I get the extra sensor readings to appear on the weather report and weather warning E-Mails?
Radio Shack version of a WMR968 and WD v10.12r
one way is to use the option to use your own custom reports,
i.e turn that option on
then go to control panel, create/edit a custom tag file
tick the appropriate one, and follow the instrucitons on the setup page
I was with you right up until ‘follow the instructions on the setup page’. Nothing happens when I click the button, and I don’t know what instructions you’re referring to.
on the create/edit a custom tag file, there are instructions on that page
basicly, tick the type of file needed
then start typing what you want to see in the file
then where you want a variable to appear, double click, then the tag list appears on the right
then select the tag, i.e highlight it, then double click it
so that it appears in the box above, then copy/paste (right mouse click to select copy or paste) that tag into the left hand window where you want that number to appear
when done, click on save
Thanks… works like a charm. Where can I find the template for the standard weather report email? I’d like to make a modified version.
report.txt
in the web files folder is the one that would have been created
or warning.txt
or if you have received a weather report email already, copy /paste that
Since I’ve been fooling with it, I’ve lost my old report.txt, it’s been relaced with the new one. I was hoping I could find one with the tags in it instead of the actual data.
here was my last report
just replace the actual data with the apropriate custom tag
CURRENT WEATHER REPORT FROM: Manukau Heads, Awhitu, NZ
Conditions: Windy
Temperature: 11.4
Conditions: Windy
Temperature: 11.4
Conditions: Windy
Temperature: 11.4
Conditions: Windy
Temperature: 11.4
