export and import wd logfiles
Hello, :smiley:
Now I’m running WD Linux :smiley: as a client of the windows server, and want to go to linux step by step until I turn off my windows computer (server) :D: . To look back I need the log files, right? I just want to know which files I should copy, or is there a export import feature? :?
the files you need are
1)log files
2)datafiles
3)webfiles
in windows copy the entire logfiles, datafiles, webfiles folders (they are in the wdisplay folder) and paste those in your wdisplay directory in linux
that is all you need to do to transfer your saved data :smiley:
and wdisplay.ini from c:\windows or c:\winnt
to the wdisplay folder on the linux pc, to keep your settings and info like windrun, all time records, etc
I did. But not all settings are now the same… The color changed like in windows but I can’t see the weekly graph… :frowning:
Help me, please!!! :smiley:
I want to see the graphs! But how? :?
[code:1]waiting …[/code:1]
you should be able to set the background graph colour in the colour setup
or delete sections in the wdisplay.ini file relating to colour settings (when wd is not running)
ohh sry. :lol:
WD linux works fine but I dont understand why not all settings are like on the wd MSwindows! And although I copied the log files I cant see data in history… :frowning:
the port was done along time ago now
so differences have arisen.,…
log files:
you should be able to view that data via view, averages/extreme
and same for the datafiles:
you should be able to view that via view, graph history
check the file extensions are stil OK
and also linux is very case sensitive for file names too
it shows data file not found
ohh and just as I tried to close averages/extreme with the “X” WD crashed!!!
i am just about to leave for 4 days away
but if you zip and email me the log file
but does that file not found occur straight away when you go to the view, averages/extreme?
if so, check the logfiles location is correct
and heck log file recording is enabled
and check you have a current log file for this month (i.e 92004lg.txt
Here now 11.49 PM.
Good Night everyone out there
or
a nice day :lol:
tired
:sleepy2:
bad timing like everytime :lol:
Oh there is no hurry with it…
The log files are summary over 60 MB!
later…
and have good 4 days without hurry :slight_smile:
:sleepy2:
day month year hour minute temperature humidity dewpoint barometer windspeed gustspeed direction rainlastmin dailyrain monthlyrain yearlyrain heatindex
10 01 2004 17 29 0.6 92 -0.5 1007.0 0 0 92 0.0 0.0 0.0 0.0 0.6
10 01 2004 17 31 0.6 92 -0.5 1007.0 0 0 92 0.0 0.0 0.0 0.0 0.6
10 01 2004 17 32 0.6 92 -0.5 1007.0 0 0 92 0.0 0.0 0.0 0.0 0.6
10 01 2004 17 33 0.6 92 -0.5 1007.0 0 0 92 0.0 0.0 0.0 0.0 0.6
10 01 2004 17 34 0.6 92 -0.5 1007.0 0 0 92 0.0 0.0 0.0 0.0 0.6
31 01 2004 23 53 6.1 97 5.7 984.0 7 12 220 0.0 11.0 35.0 35.0 6.1
31 01 2004 23 54 6.1 97 5.7 984.0 9 10 205 0.0 11.0 35.0 35.0 6.1
31 01 2004 23 55 6.1 97 5.7 984.0 8 10 183 0.0 11.0 35.0 35.0 6.1
31 01 2004 23 56 6.1 97 5.7 984.0 7 11 223 0.0 11.0 35.0 35.0 6.1
31 01 2004 23 57 6.1 97 5.7 984.0 6 11 182 0.0 11.0 35.0 35.0 6.1
31 01 2004 23 58 6.1 97 5.7 984.0 8 10 191 0.0 11.0 35.0 35.0 6.1
31 01 2004 23 59 6.1 97 5.7 984.0 8 11 224 0.0 11.0 35.0 35.0 6.1
i notice that sometimes you have to make sure the correct moth/year come up
sometimes you have to select the month again, and then it will get the data…
my old MS log files are fine… :?
how do you mean? :?
are you speaking of under view, averages??
lets say you select September 2004 on the calender on that page. Sometimes you must select September or 2004 again, even though the calender already says that to get it to load
did you get it working?
