Event Log
This error has begun to appear in the event log at the same time every day. Anyone have any ideas as to what is the cause? There is no av scan going on at that time.
Normal daily resetting wind/temperature daily value , day: 22
Normal daily resetting rain daily value , day: 22 rain today 0.0 mm
Normal daily resetting wind/temperature daily value , day: 23
Normal daily resetting rain daily value , day: 23 rain today 0.0 mm
ERROR: Access violation at address 00DD22C4 in module ‘WeatherD.exe’. Read of address 00000128 at time/date 1:00:03 PM 08/23/07
Normal daily resetting wind/temperature daily value , day: 24
Normal daily resetting rain daily value , day: 24 rain today 0.0 mm
ERROR: Access violation at address 00DD22C4 in module ‘WeatherD.exe’. Read of address 00000128 at time/date 1:00:04 PM 08/24/07
Normal daily resetting wind/temperature daily value , day: 25
Normal daily resetting rain daily value , day: 25 rain today 0.0 mm
ERROR: Access violation at address 00DD22C4 in module ‘WeatherD.exe’. Read of address 302E3659 at time/date 1:00:05 PM 08/25/07
Normal daily resetting wind/temperature daily value , day: 26
Normal daily resetting rain daily value , day: 26 rain today 0.0 mm
most likely the fire weather index update, which occurs at either noon or 1pm
not sure why its causing that error
I will update the debug version and then you can run that
I also noticed that according to lulu’s fire weather page here:
http://www.luvretirement.com/FWI.htm
it hasnt update since august 22nd, and today is august 26th…possibbly her fire weather setup needs to be checked to make sure it is enabled/configured
linda,…check your setup screen for fire weather index and make sure everything is correctlly configured and wasnt diabled somehow, for whatever reason it may have been.
OK…thank you.
