Hello, when starting WD I receive the error message “Not enough storage is available to process this command. error with loading weather dials customization ERROR: Not enough storage is available to process this command. at time/date 5:50:42 PM 3/21/2011.” in the main screen graph field. I’ve actually been getting the message for a while now. It really wasn’t a problem until I updated to 10.37Q b37. With build 37 the program won’t finish loading until I acknowledge the error in the pop up screen. What is causing the error and how do I fix it? Thank you.
try
setup
advanced/misc
main wind customisation
then click on reset dials screen
then restart WD
