Hi.
I was “ordered” to ask here about this error when starting pwsWD first time:
This small program is used to check your web server settings if they prohibit installing the PWS_Dashboard.
You only need to re-run this program if you encounter unknown errors.
check 1 : $_SERVER[“DOCUMENT_ROOT”]: result = OK, server = vindpropell.no
check 2.1 : Your current PHP version is : 8.2.10
check 2.2 : CURL support: result = OK
check 2.3 : simplexml support: result = OK
check 2.4 : GD support: result = OK: bundled (2.1.0 compatible)
check 3.1 : file_exists: result = OK
check 3.2 : chdir: result = OK
check 3.3 : file_put_contents: result = OK
check 3.4 : chmod: result = OK
check 3.5 : unlink: result = OK
check 4 : json support: result = OK
check 5.1 : load file from updates site : result = ERROR failed, invalid data data retieved: check 5.2 : load file from backup updates site : result = ERROR failed, invalid data data retieved:
There are fatal errors:
If you can not remove the errors yourself post your questions at the "PWS_Dashboard part" of the WW-forum "
