FOUS data over 24 hours old - consider obtaining more recent data.
READY or GFS/ECMWF data over 24 hours old - consider obtaining more recent data.
I cannot find a fix for this?
Check that the DST options are correctly set in WxSimate, Euromix and WxSim. They try to autoset themselves but because of the complexity of when DST starts/ends sometimes they don’t work correctly.
UK users should check the settings. I just looked at mine and they were all set with DST turned on which doesn’t start here until 30th March.
Usually, this means the data are old, because WXSIMATE failed to run. Make sure WXSIMATE is open and scheduled to run. By the way, FOUS data is only in the U.S. (I’m not sure where you are).
Let me know what you find,
Tom
