Enlarge image not working
I have just added an allsky webcam to my website using the webcam 3 block
The image displays OK but when I click on enlarge nothing happens and I cant see why
Its the same with the weather chart in the bottom right hand corner
The live video feed works ok
My website is here ringwoodweather.ddns.net:8000/Weatherflow
Any ideas would be much appreciated
Graham
my edge shows url not found on server for the webcam see attached
the chart seems to be showing ok in large mode
Thanks for the reply - yes thats the problem and I dont know how to fix it
Graham
Check this answer, maybe it helps?
Current you are using
. . .000/Weatherflow/webfilm_popup.php
The error reads “The requested URL was not found on this server.”
That is correct as that script is in the _my_settings/ folder.
The link should read
. . .000/Weatherflow/_my_settings/webfilm_popup.php
That link shows a setup-error “Script needs to be adapted to your movie first”
The satellite image pop-ups correctly with a link
000/Weatherflow/Satellite/satellite.jpg
The movie in the standard webcam block shows OK and pop-ups OK
Problem seems to persists
The link is invalid. There is a : where it should be a / http://ringwoodweather.ddns.net:8000:Weatherflow/_my_settings/webfilm_popup.php
It should read:
http://ringwoodweather.ddns.net:8000/Weatherflow/_my_settings/webfilm_popup.php
You also have to adept the script _my_settings/webfilm_popup.php
  1. Set the message line 26 to comment by adding a # on the first position
  2. Modify the line 29 iFrame code to point to your live video
Succes, Wim
Hi Wim
I think I have done as you suggested but it still wont work
I’ve obviously missed something again but not sure what
Regards
Graham
Probably a typo in my previous answer.
The line 24
die ('Script needs to be adapted to your movie first ') ;
needs to be changed to comment by adding a # in the first position
It should read:
# die ('Script needs to be adapted to your movie first ') ;
The URL which you added works OK.
It is a still image though, not a webfilm. But it will work with this “webfilm’” script and maybe later on you want to show a webfilm.
Hi Wim
Many thanks for your help - its all working now
Warm Wishes
Graham
