Ecowitt GW1000 Upload Issue
Hi guys. After two days still cant fine where to grab. Upload any data to my website from GW1000 doesnt work. Much appriciated for any advise. Hier is my site www.lentfoehrden-wetter.de
It took some time to find the uploaded file http://www.lentfoehrden-wetter.de/ecco_lcl.arr
It seems you set the location of the file in . . . ./ecowitt/index.php to “…/ecco_lcl.arr
The “…/” means 1-step below (to the root) of your website. So the data will be stored not in the ecowitt folder but in main “lentfoehrden-wetter.de” folder
Now you have to set the location in . . ./PWS_easyweathersetup.php
=> on tab “Data” questions about Weather-program / live data file we will use
==> question: How dow we get our live data? select “Ecowitt local upload”
==> question: Path to your realtime data file. enter ./ecco_lcl.arr
That location is with one point only
The file pointer is always at the location of the main executing script (PWS_index2.php) which is in your case the “lentfoehrden-wetter.de” folder
The GW1000 file is in that main folder so the file location starts it “./” which means "inside the current (main) folder.
If you run into problems, please mail me the easyweather password and I can take a look.
After all is OK, set in . . ./ecowitt/index.php line +/- 30, which reads now
 $test_mode      = true;
to comment by adding a comment mark # at the first position
# $test_mode      = true;
Hi Wim, Thanks a lot for help, works !!! :smiley: :smiley: . But Max/min temp is wrong, i think it will change in a couple of days,but temperature inside house is wrong, becouse “we’ve got data from ecowitt”. I thought it shows just lightning data. Another say how to got data from weatherdisplay programm and lightning data from ecowitt ? Thanks in advance.
You can not use your incomplete ecowitt station for the dashboard. It is just a GW1000 + a lightning sensor
    [stationtype] => GW1000B_V1.6.6
    [dateutc] => 2021-04-15 10:57:04
    [tempinf] => 52.3
    [humidityin] => 50
    [baromrelin] => 30.372
    [baromabsin] => 30.372
    [lightning_time] => 1618484185
    [lightning_num] => 12
    [lightning] => 12
    [wh57batt] => 5
    [freq] => 915M
    [model] => GW1000_Pro
So you have to use WeatherDisplay as your data source, your clientraw.txt has all the basic data.
Lightning: If your WeatherDisplay program also reads the GW1000
and
if WeatherDisplay really sees the lightning data
=> you can add the lightning data using the extra sensor upload file for WD.
ReadMe: https://pwsdashboard.com/documentation2012/36_extra_sensors.pdf
The file to use with WeatherDisplay in this download https://pwsdashboard.com/documentation2012/36_extra_sensors.pdf
You have to customise that file yourself
@kwwa
See here for a new solution Upgrade your "xyz" station with an extra GW1000 and some sensors
You can use both the WDapi and the Ecowitt custom upload for your lightning sensor.
