Yes I did but that wasn’t the question you asked . Exactly the same tagline for sunmoonimage works on my pages so I assumed that the file wasn’t uploaded to your website.
I also notice that sunmoonimage.jpg can’t be accessed from the pull down at the top of the page either, so that reinforces my guess that it isn’t present.
If you go to my Page and Right click on the one of the Small Icons
one of them is the jpg file and I can view it frm with my home page
but not as a user??
I will have to see if there is enough time being allow for my uploads…
I have cable hi speed and it is fast but maybe not fast enough…
I also had this problem when I had dial up…
Thanks for the info… gives me something to do. hi hi :lol:
I see your last tag for the sunmoon image is missing the > on the end after the align tag thats why the jpg is not showing up! I also noticed you
have the same tag twice in a row in a few spots
and then you turn the tag off before anything gets turned on?
I don't understand why this is here twice though and also why the tag is needed if it's width is 100%? I also see your sunmoon img also is missing the > at the end but it works and not his? he must have somethign else different..
You’re right, that’s all very untidy. Center is redundant if width is 100%, in fact the 100% is redundant too, just
is a full width ruler.
If you right click on the red x, select properties, and then cut and paste the Address (URL) directly into your browser Address box and it doesn’t bring up the image then the HTML is off the table and either the filename or the location is wrong, or the file isn’t there. This may not work with some free hosting sites that don’t allow direct linking to images, but they usually give an error message.
