Is there an option to disable the all-time min/max barometer coloring on the gauge face?
I use WD 10.37 b113 and just upgraded SS Gauges to ver. 2.7.4 today.
URL is https://www.familylegacy.us/wx/ssgauges/index.php
Thanks for the help folks.
-Pat
-Pat
I get Error 404 Page not found?
Same here.
That’s better
I haven’t found a setting (Mark will probably embarrass me by pointing one out) but I have discovered that the colour and its transparency [rgba(255,0,0,0.5)] is specified in lines 1645-6 and 1649-50 of gauges.js: the first two lines for the scale graduations and the other two lines for the actual coloured sector.
I have just changed my sector transparency from 0.5 to 0.3, leaving the colour as was: see Swanston Grove gauges.
That makes it less obvious, but you could play with various options. There is also a conditional expression covering these sectors, starting line 1639, for example. Just make sure you have a copy of the existing file before you play
P.S. and have a look at lines 250-3 of gauges.js for graph aspect ratio.
Thank you very much. Setting the transparency to 0.0 on those four lines took care of it!
Now to send you a “thanks”…
-Pat
