Dew Point Graph 10.13a
Is there a way to adjust the dewpoint scale? The dewpoint is lower than the bottom of the scale. Sample below:
Dan
graph setup, then use lift/lower the temperature line
try that , until it stops doing that
Yep, that worked. Thanks. I kept looking for an adjustment for the dewpoint scale and couldn’t find it :slight_smile:
Dan
yeah, the dew point shares the same scale as the temperature…
