Desperate for HELP!! [RESOLVED]
Well, you are right. . . I used to be able to check the create time box but it’s not sticky any more :roll:
I mean it always did it 10 seconds before. Perhaps a bit overkill, but it was there.
Still working on the dialynoaa and month noaa report to upload after midnight - i am doing it manually now. In the config I see 5 mins 15 30 hourly etc (which is not needed) but NOT a once daily or midnight
Let see what brian has to say
It may be possible to hand edit the ini file. I’ve done that in the past when WD would not “stick” a setting. Not 100% it will work but worth a try…you just have to find the correct variable to edit.
Brian asked for my setup files
Based on the FTPfullreal.txt he said WD still points to the old location
However, all ini and other ftp files show the correct location. EVERY screen shot I can find has the correct location
I’m SO stumped on this one.
Thanks everyone for helping !!!
Hi here is screenshot of what I have for daily and monthly reports hope this helps
BTrip
I was referencing the timing of the real time client uploads you were discussing earlier.
Thanks Btrip, didnt even think to look there
Mine does look the same EXCEPT I dont have the yearly box checked
Brian says its that WD isn’t pointing to the new web files location but every ini and screen i see does - sent this back to him
I believe this issue is resolved.
Brian found a bug in the app store version and quickly corrected it.
I still have a question and will create a new thread.
Thanks to EVERYONE for all your help and suggestions, I greatly appreciate it
