I don’t know what happened but the application stopped updating the data.
The first time the correct data is loaded, it will remain frozen.
Only the wind works.
the wind data is derived via UDP data
the other data is via the IP connection
make sure the IP address is set correct
best thing is to set a fixed IP address on your router for the davis WLL
The IP address is stable and the data is loaded but will remain the same.
If I use the Get Data button they are updated, but I would have to keep pressing it.
I do not have that problem here myself
are you using the latest app update version?
it should auto get the data every 30 seconds (the temperature/humidity/barometer data)
That you updated secretly yesterday. :-D.
Because the previous update was January 20.
But it does not matter, now runs smoothly.
I have one more question.
Using an HDMI cable, I want to transfer the application to a 4: 3 monitor from 1280x1024px, will it be expanded to the entire monitor?
i am going to have to make some changes to the app
even though davis encouraged me to make it and have worked with me (even purchased for me the WLL hardware and upgraded me to pro on weatherlink.com) and no written permission re not official app etc
someone at davis complained to the apple app store and so i have an email from apple about copyright (logo and name)…even though the logo I found on a public google search)
so I might just delete it if Davis are going to be like that (I am guessing its their lawyer or something who does not know I have been working with others at Davis) 8O
People still complain about something and someone.
The change in the application does not matter, now I came from work and the application still works well.
I have added ability to the app to get past history data, to fill in the graph data, on start up now, from weatherlink.com
(once Davis makes the ability to get the api key)
it turns out the legal department at Davis did not know that I am working with the blessing from Davis
It sounds good
Well, that’s good
Only 7 days after the last update I noticed that the average wind is not working.
I should finally wear my glasses. :glasses5:
that was only with the alternative display
