SO, I went ahead stuck a crow bar in my wallet and bought the Davis Vue. I also have the USB WeatherLink.
Can a real smart person give me a walk-through of how to get my Davis Vue setup to work with Weather Display. I have read and tried but no luck.
It’s raining like “Cats and Dogs” here in the DFW area according to my Davis Console and I’d like to get it working with WD. Thanks
Q1: OK, do you have the USB driver installed correctly? In Windows, open Device Manager (type Device Manager in the start box) and look under "Ports (COM & LPT) and you should see it as “silabs” or something similar, I have a different brand (Aten) plugged in, you should see something similar and it will confirm the COM port number.
Q2: What exactly does it say across the top of the WD main window?
Everything looks to be working fine on the Vue itself (though I don’t have it where it will be finally located yet). The WeatherLink appears to show data as far as I can tell. What I don’t have is data feeding into WD?
I have, but I will go back and close WL. I know I’m not supposed to have them both running at the same time. Even when WD is running by itself I get nothing?
I am also running VS reader because I still have my Acurite Hooked up. It was running WD but was having crazy wind and rain issues so I bought the Davis. Could that be an issue somewhere?
