Davis Vantage Pro Wireless model # 6163 setup
I decided to replace my Peet Bros system. The system has been very reliable for the past 10 years. However Pete never add any new features. Besides time for wireless anyway.
I also using the Weatherlink IP attachment. Can some one please help me or point me in the correct direction. I love Weather Display and have data ever since I installed my Peet.
I have tried but without any luck with my Davis. I did notice that my new station is not listed in the setup page? Could it be that WD does not support my ststion?
I have been able to use VWS software and had no problems with setting my station up. I still like WD over VWS.
I’m just using the DAVIS VANTAGE PRO setting under setup on Weather Display for mine been working fine for years
Make sure your data logger is being seen by the PC you are running WD on, I had a connectivity issue years ago and was frustrated, but WD supplies so darn many stations to choose from, some pretty esoteric, that with a mainstream like Davis, the problem is almost certainly NOT WD or Davis, but the wire and gizmos in between. Make sure of the baud rate, too.
the Davis IP setup is under control panel, com port setup
I do have a youtube video showing how to set that up
http://www.weather-display.com/youtubevideos.php
