I just got a new Davis Vantage Pro 2 and am trying to set the wind speed on the console to display in tenths instead of rounding the wind speeds. Does anybody know how to do this. I have looked in the manual and had no luck finding a way to do this. Any help would be much appreciated.
I guess I will have to email Davis. I found it intersting that they show the wind speed out to a tenth in the manual, but no instructions on how to set it that way. Maybe someone else on the forum has figured it out. I appreciate your help.
Can you change the units on the console display? Perhaps they’re showing m/s and therefore need the tenths to avoid having the increments too large. Also wind speed In m/s is unlikely to get to more than two digits, so they can use the third digit as tenths, where in mph (and more likely in kph) you may need all three digits.
I am displaying my wind in mph. When I change to m/s I get the wind in 1/10’s.The Davis manual shows a picture of wind speed in mph with 1/10’s (for instance 5.3mph is displayed as 5.0 mph on my console. My old WS2310 displayed wind in 1/10’s. I was just curious as to whether there is a setting in the console for adjusting to 1/10’s. Maybe there is or isn’t. Thanks for the insight on this little setup issue.
I suspect that’s almost certainly the equivalent of a typo when the illustration for the manual was prepared. AIUI the anemometer can’t physically measure anything other than integer mph. I may be wrong. but I have a recollection, maybe based on the wind calibration number but I haven’t got the WMII (which has essentially the same anemometer) manual to hand in order to check, that one revolution of the cups (ie one switch closure) per 2.5 sec measuring window equates to 1mph, but even if this figure isn’t exactly right I think the general principle is. You can’t have half a switch closure - either it happens or it doesn’t - and so your basic measurement is an integer one. Certainly the VP2 specification quotes the wind speed resolution as 1mph which ties in with what the display actually shows. And in fact the accuracy spec is the greater of 2mph or
Thanks for the great reply prodata. I think you are right on as it being a typo in the manual. I sent in an email to Davis anyway just see what they say. I guess I was so used to seeing 1/10’s of a mph in my old WS2310 console. If this is how the Vantage Pro is set up I don’t have any problems with it. I figured I would see if there was any way around displaying an integer value in the wind field.
I tend to agree with the typo theory, but you would think they would have answered the question often enough since the original VP was introduced to have fixed it in the VP2 manual :?
[quote author=nikoshepherd link=topic=7456.msg50355#msg50355 date=1107047133]
I am curious as to why Lacrosse Technologies for instance has the ability to track wind speeds in 1/10th’s of a mph. This is the main reason I stumbled upon the MPH question, given the read out on my old WS2310 console. I am sure other companies have been able to introduce 1/10th’s precision into their consoles. The primary difference between the WS2310 and Davis VP anemometer is the use of cups vs. the turbine construction on the 2310 model. Do you suppose this accounts for the accuracy differences? I guess we have something to look forward to in the future if Davis decides to implement some of the additional sensors. Oh well, I am happy with my Davis VP so far, I was just puzzled by how they were displaying wind readouts on the console. On a side note I am also stumped as to how to set the special alarms on the console. The instructions in the manual are not very thourough. If anybody knows how to set the alarms please let me know.
I don’t know. It may be that they have a more sensitive impellor mechanism. If for example this turns more than once for every mph then it may start to get the potential to read meaningful fractions of an mph unit. The main downside might be that at high wind speeds the impellor can’t keep up and starts to under-read. The Davis unit is specified to read from 2-150mph with an accuracy of
yes, the little fan type anenometer has a very high RPM , and so yes they can get DP for windspeed…that will be the reason
(it screams at 85 knots (using a compressor!)
Thanks Windy,
I guess that answers the question. If I get any different response from the email I sent to Davis I will make sure to post it here. I figured I would pose the question to the weather station experts on this forum first.
the bottom line, is that if a anenometer only has an accuracy of say +/3 mph, then showing 0.1 mph resolution is a bit pointless…
and wind changes quickly, and so you are not going to see it go through 0.1mph within a whole mph anyway, if you get my drift
I think you and Brian are right, even if you look at the high end stations, Texas, Campbell etc they don’t claim better than 1 mph. 0.1 looks good but it’s meaningless.
Just for everyones information this is the response I got back from Davis regarding this issue:
"Hello,
The wind speed on the Vantage Pro and Vantage Pro 2 only can be shown as whole numbers for MPH. The manual incorrectly shows it in 10th’s.
Tom Raymond
Davis Instruments
Technical Support
510-732-7814 [email protected]"
I guess at least they admit to the manual being wrong. Thank you everyone for putting this into perspective. I now realize that showing wind speeds in 1/10’s does not improve the accuracy of the values.
I ve had this problem bug me too. After a loooong search it is apparently a design fault/feature of the VP2…!
What happens is that the VP2 and the associated data logger only have an accuracy of ±1mph and actually store this value as an integer, therefore there is no way to improve on this value nor to display decimal mph.
When you do see decimals in the m/s display it is simply the conversion from integer mph to m/s. Again the steps in the display can get no better than 0.45 m/s. Thats just the way they built the damn thing.
