I am noticing that the graphs ( realtime and historical) are now showing sun at night time. I went through and looked for any thing that might be ticked such as Labjack ( I have none) and everything looks fine. The solar values and uv values are correct, but the time scale isn’t.
ok, I will give that a shot as well. Someday I really need to think about a wireless setup and a second computer to leave on all the time. I use this one for just about everything, including the weather running in the background.
I change from 2510 to a VP Plus 30 hours ago. The solar graphs and the data extraction work very well. I have used 5 min and now 15 min. As long as the pad is set to equal the logging interval, everything stays in place. I have started and stopped several times. Check the site.
Only issues I have noticed so far is the extremes did not get reset last night, I was using data extraction at 5 min intervals. Also the ET drops to 0 on the solar graph during the extraction times.
Between hour 21 and 23 it is short because I had the pad at 1. Could this be why yours is bunching up aardvark?
actualy there was a bug with the position of the solar data plotting in relation to the time and compared to the other parameters
i have fixed that now in 10.15q
(i can confirm that, as I acutaly had that problem myself and didnt realise!)
ET from extracted data:I have not got that working yet (could not find it in the data stream)
i will have another hunt for it, now that i have ET from the VP
