Davis possible connection schemes
I have a wireless Vantage Pro2 with additional solar radiation sensor which connects to the ISS with ~25 meter long cable. This has worked for years but the cable is getting more and more damaged.
The anemometer and solar radiation sensor are both located on the same pole. The anemometers is connected to the wireless transmitter (not cable connected to the ISS).
The question is: can I connect the solar radiation sensor to the wireless transmitter where the anemometer is connected to?
Well, you can connect it. :wink:
But the VP2 console will not see it.
You would need a WeatherLink Live, WeatherLink Console, or an Envoy8x to be able to receive the solar data.
Thanks :slight_smile:
I’ll have to stick to long cable connection then.
