datalogger Vantage Pro 2 for WDL, USB or serial?
Hello, I need a data logger for Davis Vantage Pro 2
I buy serial or USB?
serial and usb are compatibles with consolewd?
either will work, with a serial data logger you use a usb to serial convertor
I would go with the serial myself
Based on everything I have seen in threads here and even on the Windows side, I recommend the Serial Data logger. If you do not have a serial port and only USB get a good USB to Serial connector, I am using Belkin on the Windows one with no problems. You will want to validate that the USB to Serial converter will work with your release of Linux.
Mike - N8DQ
