Data Zip Backup 2.0 Crashes
I think that happens to me since the update from 1.9 to 2.0 or one of the last 7 updates of WD. I cant be more specific because it started a long time ago and it was not a big problem so far, but since I transmit data to cwop and WU it is importend for me to send stable data. I use win 7 32 bit and the latest version of WD in admin mode. Everytime it crashes that bad, that no usefull reports made to WU and cwop, because it takes all CPU power and sensor data freeze.
Thx for your help
Sven
do you use a virus checker?
if so, what are you using?
I use no extra virus checker, because the netbook is set up only for WD and WDLive. The only thing that’s installed is microsoft security that comes with the updates. I edit the first entry because i just find out, that it also crashes during manually backup. It starts backup some files (you can see it at the window) and crashes at no specific point.
