Data received - stops - Davis VP2
Richtonite
Apologies for late reply, If you look at the two charts and see he time values in the centre (in Red) and look at the charts time. The first one was when program opened , you can see the bottom chart with sunshine NOT matching the expected sunshine as it is offset from gray sunshine line.
The second chart is AFTER I downloaded the data from VP2, using the ‘Action’ option ‘extract data from …’ to get missing data, then redraw the graphs…
You can see the data discepency in both charts…
cheers
