Data-Quality-Problem since V10.37f B11 with WMR918H
Hi!
Last version I’m now using and will work perfect is V10.37f B09 (rolled back!).
The normal-way when WD start’s with my station (WMR918H; wind-sensor AND rain-collector actually not installed!):
First all fields are blank (normal!), then “data received”-LED is blinking green when data is coming in while the “data quality”-LED is red for a certain time. After a few green-flickering from the “data received”-LED the “data quality”-LED changes to green and all is working well.
Since I’ve tried to Update to V10.37f B09 (and also in actuell build B12/13(?)) WD do the following:
First all fields are blank (normal!), then “data received”-LED is blinking green when data is coming in while the “data quality”-LED is red for a certain time. SO FAR IT IS NORMAL/OK, but then after a few green-flickering the “data quality”-LED will not change to green! Instead it changes first from red to grey and after that it flickers in the same rhythm with the “received”-LED (which is green flickering) in RED and nothing will go on. At this state only the outdoor-temp and outdoor-hum is displayed but no other data will appear. I was waiting about 5 minutes but this state will not change anyway.
What’s wrong?
Cheers,
Denis
I made a change ,for the better if I can iron out the problems, for the wmr918 station (the older version (the wmr968 is the new model)
but maybe my idea of merging the 1 stations is not going to work?
(the problem will be with the barometer data)
i will review what i have done and look to see wether to change back to the way it was or to try and get working
(i was trying to avoid the problem of where people were choosing a wmr198 station when they actualy had a wmr968 station
try a new .zip download and let me know
thanks :wink:
Hi!
No, Sorry. It’s near the same behavior.
Now the quality-LED is from the beginning grey, then receive-LED blinks from time to time green and about every 3rd or 4th time the quality-LED blinks red… in-between the quality-LED is grey even the received-LED blinks green.
Cheers,
Denis
fixed as per your bug tracker feedback, in the latest update of WD
