I run weather display latest version with my ws2300 station. Its on com port 1 no problem everything works ok and weather display plots all the data. The problem is since the 11th march the graph gets to 22:00 hrs and just stops. I can get it going ok but takes some messing about. Also it now is not updating the days totals, the 11th was the last entry. When it starts recording again it works perfect up until that time. I wish the pc to run non stop 24hrs a day. Any ideas
Window xp
WD latest version
Com port 1
La Crosse ws2300
there is nothing special in WD about hour 22
when you say it stops, do you mean no more current data from the station?
(data received light stops flashing)?
check that you dont have some program starting up then that would use the com port or similar
The graph just stops recording at this time, WD still shows the data i.e temp and the other things and it still shows connected to com port 1, the data light flash however the data received reading don
it looks like it stops just before 22:00
are you able to be arond then to see what happens?
I will tonight Windy however i have just install it again. Was only going 5 days so not much lost will try again tonight…
Are you running Heavy Weather at the same time as WeatherDisplay (you have HW listed on your website)? Perhaps that is the problem, as I believe it is recommended that you DO NOT run Heavy weather whilst using WD.
thats most likely the problem
(heavy weather will then be grabbing the com port)
