For the past two weeks (beginning March 29) my APRS RF packets have not been making it to the MADIS. Call sign KC3BHK-2, CWOP identifier AU875. Packets are making it to FindU. I discovered this problem using Windalert, which links the station data to forecasts. When I contacted support for windalert they replied
“ I pulled up your station on WindAlert, and it is marked down. Since you broadcast your data through MADIS, it is likely there is a connection issue between your weather station and MADIS since we pull the data directly from their server. Can you check if this is the issue? Our last reported observation is from 3/29 at 10:46 in the morning.”
I’ve sent email to phil gladstone about the issue, but no response. A few weeks ago my model airplane club noticed that the display we used to use for the weather info on findu stopped working as well, apparently due to a security certificate being expired. Are the two issues related?
Can anyone give me any insight on whats changed since March that’s causing this issue.
Brad
