Since 12 September I have been having to update the detailed climate report and then upload the dailynoaareport every day, I have now discovered that the dailyreport.htm has stopped updating since the 12th. I haven’t changed anything and am using latest version.
What is the fix for creating the missing days please and any ideas as to why it stopped creating the file.
Do seem to have an ongoing problem with these reports updating especially at the end of the month.
no problems here
http://www.weather-display.com/windy/gb/dailyreport.htm
or for this site (using build 78 as well)
http://www.portunus.net.nz/weather/dailyreport.htm
make sure you have set to upload, under view, av/ext, in the internet upload tab
Hi Brian, thanks for the response.
It is not the upload to the internet that is the problem with the dailyreport.htm it is not creating the file locally first.
Under av/ext the first two tabs show the correct data but the detailed climate report is not updated either until I manually update the month and then I can update the dailynoaareport.htm but I am having to do it every day and that is when I noticed the dailyreport.htm had stopped being created.
I ran the convert logfiles, recreate the last 31 days and then recreated the web av/ext pages which created the missing data on the dailyreport which I could then upload to the internet.
But again this morning it hasn’t created yesterday’s data again and the detailed climate report hasn’t updated again either, presuming there is a link between the two.
This is weird as usually it corrects itself after a manual update.
After finding that Avast AV version 6 is problematic with XP, I had to do a system restore. Finally managed to get missing data off the data logger, except I find that duplicate data doesn’t match exactly, e.g two exact times show different wind readings?
Back to version 60 at the moment, everything running OK. Corrected logfile, converted to data file and recreated last 31 days so under view, the av/ext, noaa style reports and detailed climate report are all correct and the dailynoaareport.htm are all correct, but the dailyreport.htm is missing several days and even though I have tried to recreate the web av/ext page and it is counting through all the days it is not updating the file.
Any ideas as to what I am missing out here.
This is not a problem uploading to the internet, that is working OK, but the files are not being created locally.
I have this problem too. My dailyreport.htm stopped updating on Sept 13.
http://tuscawilla-weather.net/dailyreport.htm
I’ll be watching this post too.
not enough informaton provided to be able to provide any help weather pilot
i.e need to know which version and build of WD
and if any error under view, program error log
and also to make sure the needed settings are set (you have not provided any information on those)
Sorry Windy - didn’t expect a response - thanks for your help - will attach data to this thread later today -
Best regards -
Greg.
how do you mean you did not expect a response?
most likely there will be an error under view, program event log
