Hi Folks!
Is it possible to make produce txt-files os NOAA daily reports,dailynoaareport.htm, (as automatic, produce/upload ) or have I to copy/paste them from average/records-tab?
Best regs
Henkka
Hi Folks!
Best regs
Henkka
you can set to create and upload the dailynoaareport.htm file
see under view, averages/extremes, 2nd to last tabâŚ
is it possibile to produce the noaa reports in txt format instead of html?
yes
if you change the noaa report header/footer template files and remove the html code there
Just tried your "October 11, 2007, 11:52:05 PM " suggestion.
I am afraid that it does not work.
If HTML header and footer are deleted in the ânoaahtm0.txt and noaahtm2.txtâ and not regenreated,
in the ânoaahtm1.txtâ the
tag is always regenrated.I did not also find a way to a save as: dailynoaareportxxxx.txt
Also how can I ask WD to generate these reports (including annual) automaticaly�
Thanks for any help.
Regards.
-= Guy =-
Hi everyone and body WD vers: 10.377R b 286
As said in my end of July post and unanswered for now, the is a bug while customizing the
noaahtm0.txt, noaahtm1.txt and noaahtm2.txt files.
I have erased all html tags in these files for I want to use only the text data with a
third party software.
Problem, bug as shown on the attached pict, the
html tag remains in the converted file.
Correction will be deeply appreciated.Thanks, regards.
-= Guy =-
with that html tag, then the text will not display correctly under html
the next update of WD will have it in the noaahtm0.txt file instead
I could agree with you, butâŚ
One that wants to customize (as I) may want to convert these xxx.htm files to xxx.txt files.
I so need completely blank templates.
Thanks for giving WD that possibility.
A third party software changes the extension of the files in my case.
Thanks, regards.
-= Guy =-
PS: Please do not forget the WDmysql problem.
I have the latest version of WD (09/05) 10.37R293
The
problem is still there. It shows up in the dailynoaareportxxxxx.htm file.The problem is even getting worse as long as dailynoaareportxxxxx.htm only takes
the 5 first days of each month�Sorry. Thanks for fixing.
-= Guy =-
Regards.
-= Guy =-
Brian,
Suggestion
Give an option for WD to save directly a dailynoaareportxxxxx.txt file keeping both possibilities of course.
Thanks, regards.
-= Guy =-
Little update on the new problem.
dailynoaareportxxxxx.htm only takes the number of days equal to the date of month�
And of course the
HTML tag is remaining in the customized template.Thanks for correcting. Regards.
-= Guy =-
I have tested and its working as you want it here
you though need to delete the noaahtm0.txt, noaahtm1.txt, etc files
so that WD recreates them
and puts the
in noaahtm0.txt
then remove that from there
OK Brian,
The
problem is fixed, thanks.But the NEW problem since version update is remaining.
If I select 8/2008 as date to calculate and then
click on âUpdate whole month nowâ, every things for now is OK
The whole month is generated.
Now if I click on âUpdate daynoaareport.htmâ, for the same month
Then ONLY the dates from 01 of the selected month and year
to actual number of the day of actual month is regenerated.
This bug did NOT exist in previous versions.
I can post picts if needed.
Thanks form fixing.
Regards.-= Guy =-
I am not able to duplicate that problem here myself
[b]1st pict NOAA montly report correctly regenerated for 2008/08
[/b]
2nd pict generation by updatedailynoaa.htm
3rd pict display of dailynoaareport82008.htm with Notepad++
[color=blue][b]Note the calendar date on the upper right part of the PCâs screen. ( 8th of september)
dailynooareport82008.htm goes no further while basic noaa report is OK.
Same result for any month regenerated. Picts available on demand.
Regards.
-= Guy =-[/b][/color]
that is happening here
I can post screen shots if you like
I guess that meens you reproduced the problem.
Thank you for fixing it otherwise NOAA reports are
unusable.
Regards.
-= Guy =-
what I meant sorry Is that is not happening here
Brian⌠BrianâŚ
You give me the clues to customize noaahtmx.txt files to get a pure x.txt noaa report. (No HTML tag)
OK I do so⌠And it works now, NO tags. BUT WITH THE BEFORE DESCRIBED BUG. (300% SURE)
Now if I basicaly have WD regenerate the noaahtmX.txt file every thing works OK.
PLEASE when you trouble shoot use same configuration as one reporting.
1-) Nothing customized == everything OK
2-) Customized with NO HTML tags in the reports == BUG == regeneration ONLY up to curent date day.
Please erase ALL HTML tags in the three noaahtmX.txt files and test after⌠==== BUG
Thank you for correcting that definite BUG.
Regards.
-= Guy =-
I still cant duplicate
I try
noaahtm0.txt and noaahtm2.txt empty
still no problem, noaahtm1.txt contains all 31 days for say august last year (or any year I choose)
are you sure you are using build 293?
