Daily graphs not being created
Somehow I turned off the creation of daily graphs. I can’t find where to turn it back on.
Help… :oops:
Do you mean the graphs in the main window? Or?
check under ftp/internet setup, upload file times
there is an option there
Thanks. I rechecked the box I needed.
Is there a way to go back and recreate these?
They would be the files called 20061225.gif as an example.
yes
use the recreate the averages/extreme function under view, averages/extremes
and then you will have to upload them
I guess I didn’t check the correct box. :oops:
Which one should I have checked?
Thanks again…
This is version 10.37c build 13
post a screen shot of the upload times setup, in the ftp/internet setup
www.thanko.info/times.png
you need the top seting ticked, do the averages/extremes upload
thanks.
